Note* not sure what this stuff is actually worth if you feel im asking to much and are interested throw me an offer, worst i can say is no.
Located in Wa
Text on 0447 257 555 or PM
Willing to ship at buyers expense
RB26 OEM Plenum, throttle body and runners $450
Greddy Fuel rail and 800cc Injectors $600
Nitto Clear Cam cover for RB26 $75
Nismo Oil cap $50
HKS EVC-S Type S boost controller $175
Walbro 260LPH E85 fuel pump, Brand new $200
post-135401-0-08559100-1456137442_thumb.jpgpost-135401-0-59369400-1456137444_thumb.jpgpost-135401-0-65617500-1456137447_thumb.jpgpost-135401-0-16564300-1456137450_thumb.jpgpost-135401-0-08250600-1456137452_thumb.jpgpost-135401-0-17515500-1456137457_thumb.jpgpost-135401-0-29937800-1456137455_thumb.jpg
Edited by TexGTR
https://www.sau.com.au/forums/topic/463139-misc-rb26-parts/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
