Accidently posted this add in wrong section - reposting here.
Full set of 60mm genuine Defi BF gauges in amber. Comes with controller, harness, and extra Defi warning lamp which alerts driver if one of the gauges reaches preset limit.
I bought these to fit to my RS4S, only the water temp and boost pressure gauge have been used (perfect condition) and the rest were never fitted and still in the boxes. There is a blue box but the gauge inside is amber - it was last in stock at the retailer I bought it from and I got a discount for having the incorrect box. Has been checked - is definately amber.
I don't often get on this site anymore but if you PM me it will pop up in my emails and I'll get back to you.
Offering them here cheaper than Gumtree or Ebay. $1600
Luke 0401751691
  • 2 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
