Ok M35 guru's could you please take a look at these pics and tell me what you think. This is my car at idle in park after driving for 20 minutes. It is still missing after now changing spark plugs, checking coils, changing MAF sensor, crank angle sensor, and left bank (passenger side) cam angle sensor (haven't done other side yet but pretty sure that aren't the issue).
Also checking for any leaks in all piping (found a small crack in PCV pipe which is fixed now). and have reset computer..
My concerns were with the timing figures but in saying that i dont quite understand how to read this Hobdrive information as yet.
Thank you for any help as this is really shitting me now...
https://www.sau.com.au/forums/topic/465219-m35-stagea-running-like-crap/
did you check PCV valve when you change PCV pipe? the brand new one should be one-way valve and my stock one become 2-ways. not sure if it will affect idle.
your idle in P at 1000rpm? can you see AFM voltage? normally it should be around 1.45v and rev should be around 650rpm when idle in P or N
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
