1973 240z
Brisbane
45k, but would be interested in an R32/R34GTR Deal
I bought it 3 years ago now, with the full intention of turning it into a JDM princess and enjoying it.  Unfortunately the best laid plans don't always work out.  As the car needed more body attention that i originally thought, rather than restore the car and not enjoy it at all for 5 years, i chose to rebuild it mechanically and leave the restoration (read: respray) until a later date.  The car has been finished for about a year now, and i just cant seem to get the energy going to strip it down, have the body redone, and put it all back together.  It would be lucky to have driven 1,000ks in the 3 years ive owned it.
I should clarity right now, this car is 100% driveable.  It starts, runs, idles, brakes and steers excellent.  The ONLY thing it needs is the rust removed, paint redone and new parts installed (to replace the old ones you wouldn't want to re-fit after restoring it).  If someone didn't want to repaint this for another 5 years, there is nothing stopping you from enjoying the car and driving it anytime.
With that in mind, i have decided to do an EOI on it to see if someone else wants to run the final 100m of this race and have one of the best 240Zs in the country.  Apologies if there are rules against EOI, but either way i would struggle to put a price on this as the current market (Car Sales and Gumtree) is extremely inconsistent.  Anyway, lets start with the good bits.  As you can tell by the list below, this car had a very specific goal in mind, which was to completely replace everything which was old and crap, and replace it with as much JDM goodness as i could find.  A lot of the work on the car (MCA coilovers, S2000 seat mounts, stack gauge surround etc) has been created by myself or D3C0Y and cant be bought off the shelf.  In short, i have spent a lot of time researching and finding the best bits for this car, which are what is going to make it very well sorted.
The Car
1973 240Z
Engine and driveline
  •   L28 F54 Block (engineer approved)
  •     P90 head
  •     280 duration .495 lift Wade Cam
  •     MSA performance valve springs
  •     Triple 45mm SK Racing Carbs with velocity stacks on TWM manifold (restored by Lou Mondello and jetted/tuned by CnJ Motorsport)
  •     180HP ATW
  •     Kameari heat-shield
  •     Alloy catch can
  •     Adjustable alternator bracket
  •     Redline fuel pressure regulator
  •     Light weight Flywheel (4.6kgs)
  •     Excedy HD Clutch
  •     Fujitsubo headers (HPC coated)
  •     Fujitsubo Legalis R stainless exhaust and muffler
  •     280ZX Electronic Distributor
  •     3 row 56mm aluminum radiator with twin 12 inch fans
  •     280z 5 speed manual
  •     New clutch slave cylinder
  •     New upper and lower thermostat housing
  •     New lower water inlet
  •     Chrome bolt kits and replaced bolts in many places
  •     4.1 R200 LSD
Suspension, Brakes and wheels
  • Front and rear (cusco) strut bar
  •     Front and rear white-line sway bars
  •     Front and rear adjustable end-links
  •     MCA blue series coil-overs (front inverted mono tube with 5.25kg springs and rear non-inverted with 4.5kg springs) (engineer approved)
  •     TTT Adjustable front and rear lower control arms
  •     TTT adjustable castor rods
  •     260Z front hubs
  •     280zx 15/16 master cylinder
  •     300ZX 4 pot aluminum calipers with braided brake lines (engineer approved)
  •     Front 300mm vented and slotted RDA disks
  •     New handbrake cable
  •     R31 rear calipers (solid disk) with braided brake lines (engineer approved)
  •     Rear solid RDA disks
  •     New tie rods
  •     New wheel bearings
  •     Watanabe RS 16*9 and 16*9.5
  •     Toyo Proxy T1R 225/50/16 and 245/45/16
Interior
  • Honda S2000 seats mounted to stock rails (engineer approved)
  •     More new bits, screws, fasteners and clips than i care to count
  •     Electronic ignition (Original tacho modded to read electronic signal)
  •     Nardi Steering wheel
  •     Replica leather handbrake and gear boot
  •     Original 5 speed shift knob (plastic slightly cracked but wood is good)
  •     Restored center console with Fairlady Z badge
  •     Stack Oil Temp, Oil Pressure and Voltage gauges
  •     All lights work
  •     Billet map light surround
  •     New hatch and footwell carpet
  •     New passenger side grab handle
Exterior
  • Kameari Front spoiler
  •     Replica 432 rear spoiler
  •     Replica ZG flairs (body cut and welded)
  •     Reconditioned front and rear bumpers
  •     Genuine 510 Chrome fender mirrors
  •     Navara glass headlights
Spares (to be installed after painting)
  • Brand new diamond pattern interior trim (front and rear)
  •     Brand new roof-lining and A pillar trim kit
  •     Brand new full rubber/seal kit
  •     Brand new pedal rubbers
  •     Drivers side outer window rubber
  •     Fairlady Z dash emblem
  •     Genuine Fairlady Z badges
So what needs to be done?
  • It needs to be repainted.  It was resprayed over the original green and the surface was not properly prepared.  So there are some areas where the paint has split, has gotten silicone/moisture underneath which has caused imperfections.
  • Rust to be removed.  The only rust i have seen (and i have been working on the car for a few years now) is in the bottom of the doors and one spot under the rear window rubbers.  That doesn't mean there isn't more, but its not showing anywhere else.
  • It also doesn't have a roofliner, because the original one was replaced by some horrible white fluffy thing which fell off as i was driving from Brisbane to the Sunshine coast.  Rather than fit the new one, i was waiting until it was resprayed so i wouldn't have to pull it out twice.
  • There is a small leak in the tappet cover gasket from the head not being perfectly flush (bottom of head was planned so the headgasket is a perfect seal), one small leak from the front cover gasket and one small leak from the front of the diff.
  • The Dash is cracked, and currently has a cover on it.
  • Like 1
https://www.sau.com.au/forums/topic/466164-1973-240z-bris/
been watching carsales/z240 forum/facebook for the for sale/progress of the car.
"It needs to be repainted.  It was resprayed over the original green and the surface was not properly prepared.  So there are some areas where the paint has split, has gotten silicone/moisture underneath which has caused imperfections.
The Dash is cracked, and currently has a cover on it "
can you take pics of these areas?
just to better judge if repairable etc
thanks
oh also if you don't mind take pic of where you had the guards chopped under the fender flairs please. would like to see how clean they were done :)
https://www.sau.com.au/forums/topic/466164-1973-240z-bris/#findComment-7764511
Hey Ken,
Not a problem, i have rust pics on hand, but not the guards.  I will take those later.  The only one i cant do is the dash, as the dash-cap is glued on.  I haven't peeled it off, but reskinning is $800-$900 from the Dashboard doctor in Melb.  That's who i would send it to anyway.
  1. Drivers side (in front of rear wheel)
  2. Hatch
  3. Passenger side (in front of rear wheel)
Edited by Deus_Ex
https://www.sau.com.au/forums/topic/466164-1973-240z-bris/#findComment-7764565
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
