For sale is my Black VE Holden Commodore SS. We recently purchased a large SUV so we no longer need this car so this second car is rarely driven therefore I'm looking to downsize.
I have owned the car for approximately two years with no issues whatsoever. The previous owner had it regularly serviced at a particular mechanical workshop and so I have continued to have the car maintained by the same shop with a complete log book as evidence.
Mechanically the car is excellent condition and the exterior presents nicely with only minor scratches as would be expected for a used vehicle. The interior is also very neat and tidy.
I have recently spent approximately $10,000 on modifications and upgrades and have all the receipts to pass onto the new buyer. All this work was done less than 2000 kms ago.
Details
Make: Holden
Model: Commodore VE SS
Year: 2007
Engine: L98 6.0 litre V8
Transmission: 6 Speed manual
Odometer: 141,000 kms
Price : $18,200 ono
Modifications/Upgrades
- Camtech 228/234 camshaft
- Dual valve springs
- Titanium retainers
- Double row timing chain
- Lifters
- Pushrods
- Head machined and serviced
- ARP head bolts
- Metal Head Gasket Set
- New Rocker cover gaskets
- New Iridium Spark Plugs
- New Harmonic balancer
- New Front seal
- New Radiator
- New Coolant temp sensor
- New O2 sensor
- Xforce 1-7/8 stainless steel extractors
- Xforce 2.5inch Cat back exhaust with 100 cell hi flow cats
- VCM OTR cold air intake
- New Alternator
- VF SS Storm wheels and Bridgestone tyres (approximately 4000kms old)
- 3.9 diff ratio
- Mafless tuned at Autotech engineering making 315rwkw.
Looking to sell quickly so price is negotiable for serious buyers, but please no time wasters. Will consider trades/swaps for cheaper (with cash my way) or similar priced sporty cars.
Feel free to contact me on 0407 931 097 or PM for any further questions.
  • 4 weeks later...
  • 1 month later...
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
