Spoiler
For Sale: Nissan Skyline R34 GT-T
Back Story:
- Imported in 2010 through Skyline City Imports this car has been carefully looked after and is still in the same condition as when I bought it
- All paper work regarding its import as well as the export papers from Japan are available upon request
- Prior to importing this vehicle it was owned by 1 owner in Japan - It has been serviced at regular intervals and has only run on BP Ultimate 98
- When I received the car it had done 92,xxx kms, currently it has just ticked over 100,xxx kms and had its major service completed last year
- This car has only been driven with care and has never been thrashed, for this reason it has never given me any problems and is in fantastic condition mechanically and physically for its age
- Unfortunately due to my work and day to day activities this excellent car is no longer suitable for my needs and I would rather see it go to someone that can appreciate and enjoy the car than let it sit at home
Modifications:
When I received the Skyline it had minor modifications which consisted of:
- An aftermarket exhaust system
- TIEN coil overs
I have continued this trend and only added a few additional items to ensure that the R34 remains in excellent condition I have added the following modifications:
- Cooling-Pro Stealth Series front-mount intercooler to replace stock Nissan side-mount intercooler
- K&N POD filter to replace stock Nissan air box filter
- Shift Kit modification on transmission installed by MV Automatics
Additional Extras:
Aside from the modifications listed, I have added a number of extras onto my Skyline, all of which has been installed professionally.
- Complete Alpine Type-X sound system with Alpine Double-Din display and reversing camera
- BRIDE Low Max racing seats for both driver and front passenger
- RAZO gear shifter and pedals
- Re-upholstered leather steering wheel and dash
- Defi gauges and gauge holder to replace Nissan stock gauges - 2001 Nissan Skyline GTR wheels with TOYO tyres (excellent tread)
- Mongoose Immobiliser and Alarm System - 1999 Nissan Stagea Fog lights with programmed on/off switch
- Auto-Platonium HID Xenon headlights
Price:
This is arguably one of the cleanest R34 skylines that I know of, as mentioned it has never been driven hard and has been carefully looked after. Along with the modifications and extras that have been installed in the car I am looking at $15,000 o.n.o
https://www.sau.com.au/forums/topic/466465-sold-1999-nissan-skyline-r34-gt-t/
  • 1 month later...
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
