Hi mate, ive got a brand new set of apexi el gauges in black with white face and they are in boost, oil temp and water temp. And comes with the control unit and daisy chain wire.. all are new in boxes. Genuine... they have the warning settings and stuff.. Cheers mate
https://www.sau.com.au/forums/topic/466779-wanted-gauges/#findComment-7774947
Hi bro, i got them through apexi and if u look on there site they are about $850- $900 usd for the 3 with the control unit.. i cant remember but it was abit i payed.. (around that) im willing to let them go for $750 aud... my loss is your massive gain.. and they look mint at night.. Cheers
https://www.sau.com.au/forums/topic/466779-wanted-gauges/#findComment-7775198
