For sale as a package is. 2 Garrett GT2860-5s that have just been upgraded to GTX2860-5s billet compressor wheels, which flow up to 40hp more per turbo then the original GT series and spool quicker also. These turbos have been upgraded/balanced by a reputable shop and I have invoices.
Brand new 2 GTX2860r-5s would cost you $4000+ Canadian and im looking for $2600 Canadian which i believe is also 2600AUD and they come with wastegates/ported stock manifolds and 6boost metal exhaust gaskets.
Message me if interested or want more details.
https://www.sau.com.au/forums/topic/467030-gtx2860r-5s-ported-manifolds/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
