Has anyone had any experience using TRW brake pads on there GT-T? I see alot of people recommending using the Intima SR pads but have also read that TRW are quite good and top quality (better than EBC green/yellow/red stuff). If anyone could give me some info and thoughts on them from previous use it would much appreciated.
https://www.sau.com.au/forums/topic/467056-trw-brake-pads-or-nah/
They are an excellent pad.  Very under-rated or perhaps just not as well known/marketed as other brand names.
I used them for road and occasional track, probably used 5 sets over time.  Price and performance is spot on for that sort of application.  Not too dirty, and didn't eat rotors.
  • Like 1
