AEM UEGO Digital Wideband Air /Fuel Gauge kit with AFR Sensor
#30-4110
As title says, Brand New still in box and packaging.
Bought 2 months ago, but sold car recently.
Have no use for it.
Selling for $270.00 delivered anywhere in Aus
GFB G-Force II Electronic Boost Controller
Have no use for it.
Selling for $250.00 delivered anywhere in Aus
Turbosmart Comp Gate 40 - Black 7psi (BRAND NEW)
As title says, Brand New still in box and packaging. Black 7psi
Have no use for it.
Paid $450
Selling for $350.00 delivered anywhere in Aus
5 hours ago, Yeedogga said:
Hey mate Ill take the wideband. Ill PM u shortly for details.
AEM Sold sorry!
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
