Kangeroo juice!
Hello!
Browsed this site a lot whilst looking for a M35 to buy and after for mods etc, it's been very helpful. But I've signed up to ask a question of my own as I can't seem to find an answer.
I've owned my 250 RX Four about 2 months now and I love the car. Except the past week it's developed a really weird wobble. The car shakes backwards and forwards between roughly 20kph and 70kph. It feels like I've fueled the car with kangeroo juice, which I promise I haven't here in NZ!
It does the wobble regardless if I'm on or off throttle, doesn't come through the steering wheel and the car pulls straight. I'd like to say it feels like it comes from the rear but I couldn't be 100%.
So far I've checked the basics, wheel nuts are tightened up, had a quick look underneath and nothing looks out of place. Done a quick finger gap test of the arch gap on the rear and it's the same both sides. Revved up the engine and it didn't seem to flex too much so engine mounts seem fine.
My next thought is wheel balancing, I do need to change the rear tyres soon so fingers crossed that solves it.
But until then what's people's thoughts on what I could be or what I could check?
It's annoying as I have next to no tools and only the boot Jack to lift the car as I'm only here as a back packer from the UK.
Cheers guys!
Oh here's a picture of it too, just cause no one likes to look at topics with lots of text and no images.
https://www.sau.com.au/forums/topic/467530-kangeroo-juice/
You haven't accidentally turned on the atessa lock (the one that lights up the two axle light assuming that the M35 is the same as the C34 in that regard)? Loose universals on the driveshaft? Recently fitted unequal front and rear tyres?
https://www.sau.com.au/forums/topic/467530-kangeroo-juice/#findComment-7787917
maybe wheel bearings..
jack up each corner , and check wheels for play.
grab the tyres , push and pull hard in all directions
otherwise gearbox or tcu could be playing up.
have you or the previous owner had the transmission serviced ?
fluid needs changing every 80000 km
https://www.sau.com.au/forums/topic/467530-kangeroo-juice/#findComment-7787933
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
