After just loosing my license for an absolute Bullst reason, I've decided to look at it from a good point of view....
I'll have a long 3 months to strip down my R33 GTS-T.. give it all a clean/lubricate and hopefully put it all back together in the same way I found it.. then again there is always a couple of nuts and bolts afterwards and your left wondering where did they once fit..
Well anyway I was just wondering if anyone had a downloaded version of the RB25DET workshop manual or where I could download it?
Don't tell me everyone in here is legit and not one person has bought or downloaded a pirate version.
If you have one give a fellow skyline buddy a hand.
https://www.sau.com.au/forums/topic/46804-its-gonna-be-a-long-3-months/
How'd you go about putting it all back together?
I'm pretty good mechanically but im worried if i completely f*&k the whole thing and forget to plug a hose in or leave somethign out and then it gets back to me in the end.. when im driving down the road.. look in my rear view and see my turbo flying down the road...
you'll be alright dude, i recently put a new engine in my car and was thinking the same thing, but once u get going, everything is reasonably straight forward...
when u first look at the engine bay you'll probably think to yourself 'what an abortion', but if u either tag or mark individual groups of bolts to nuts and threads, or video your work you should be sweet, and most of the wiring and clips will sit fairly steady in their original positions if u know what i mean...
Thats true.. i guess its not brain surgury..
Welcome to the club of vic lost licenses :D
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
