Racepak IQ3S
I am selling my Racepak IQ3S which is still brand new unused in box.
Price $1550 + postage. Pickup is in SE VIC or South Yarra/Prahran during working hours.
More information can be found at http://iq3s.racepak.com/
NB - check yourself before you wreck yourself
  • Like 1
https://www.sau.com.au/forums/topic/469061-racepak-iq3s/
5 hours ago, ISLIDE013 said:
Bit confused as the price on the link you shared is $970
To be fair, the link pricing is in $USD and you would have to add shipping on top.
But in saying that, i had a quote come through yesterday from Haltech for a lot less.
https://www.sau.com.au/forums/topic/469061-racepak-iq3s/#findComment-7811071
Just now, JimmyRickard said:
if its a logger dash its not bad value
I dont think the make the street version with a logger do they?
https://www.sau.com.au/forums/topic/469061-racepak-iq3s/#findComment-7811193
That price is in USD
14 hours ago, Coullsy said:
Haltech are $1200 + Postage
Yes you are correct, Haltech is $1200 + postage, for the bare unit only...
10 hours ago, Coullsy said:
Yeah they do, the logger version is $1900 + postage
But the link provided and the description above it seams to be just the standard version
Yup it's just the standard version, not the logger version
https://www.sau.com.au/forums/topic/469061-racepak-iq3s/#findComment-7811351
At the end of the day, I'm selling the product for less than what I got it for for, I'm not ripping anyone off.
I'm just over trying to prove myself because you get alot of idiots saying they can get the Racepak for 1k then link me to the normal dash... then realising they wrecked themselves, then deleting their post. But bless the person who invented screenshot :17_heart_eyes:
Hence the note of "check yourself before you wreck yourself".
https://www.enginemaster.com.au/racepak-iq3-street-dash-display-r250-ds-iq3s-not-data-logger-7-25-x-4-x-1-125.html
http://www.vpw.com.au/Category/Index/549508?Brand=Racepak
A bit of googling will result in the difference, I've highlighted it bold.
http://www.haltech.com/iq3-dash/
– Haltech IQ3 Street Dash
– Dash mounting hardware
– 34 pin AMP main connector, Colour coded wiring harness & spare pins
– 2 Programming buttons
– V-Net Male Terminating Cap
– USB Programming cable
– USB Memory stick with Racepak Datalink II software & Full Installation Manual
– Haltech Quick Start Guide
– Haltech and Racepak sticker set
IQ3S Street Dash
Mounting Studs and Nuts
Wiring Harness
Two programming buttons with pigtails
Racepak sticker set
Programming Cable
Programming Software and Installation Manuals
1 Oil Pressure Sensor
2 Temperature Sensors
https://www.sau.com.au/forums/topic/469061-racepak-iq3s/#findComment-7811396
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
