well...doing that wouldn't be street legal, but if you mean for track use....yes, you can just vent the cam covers to atmosphere, preferably through a decent sized catch can and also add a small filter on the exit to stop anything getting sucked back in.
  • Like 1
The pcv will only be pulling in vapors under vacuum when you are not on boost, Once on boost vapors are sucked through the cam cover to intake hose.
So as said you can block off the intake side that connection, but you would want to vent the cam cover, as this is where vapors will be expended when not on boost. It doesn't need a catch can as there is no vacuum being applied to it. But I would definitely recommend keeping the cam cover to intake hose(with a catch can in between), as this will be producing a vacuum under boost which is what you want.
  • Like 1
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
