GTR
R32 under bonnet mat, used good condition $50
R32 gtr ecu $100
R32 gtr knock sensor loom, discontinued part from nissan, new $150
R32/33 gtr coil pack ornament $100
R32/33 gtr exhaust manifolds $100
R33 gtr oem dump pipes $50
R33 gtr oem turbos $100
R32/33 gtr turbo inlet pipes, the cast alloy ones $50
R33 gtr oem front diff $100
R32/33 gtr fuel rail $50
R32/33 gtr tps $50
R32/33/34 afm's $100
R32/33 gtr CAS x 2, $100 each
R32/33 gtr coil pack set $100
R33 gtr alternator $125
R33 gtr complete cold side, inlet manifold, throttle bodies, plenum etc $475
R33 gtr coil pack loom, $75
R33 gtr balancer, $50
RB26 N1 block new, $4995
R32 GTST
Complete boot lining 4 pieces inc carpet $150
Boot lid $150
Type M rear spoiler $150
Type M front bar, professionally modified to fit and allow airflow to a large front mount $250
Type M brake calipers, front and rear $400
MISC
HKS super hybrid panel air filter, less than 200km use, suits all rb air boxes, as new $25
All parts located in Brisbane, please contact via pm only. Postage available at your expense or pickup on the northside!
Edited by Gts-t
https://www.sau.com.au/forums/topic/469901-gtr-and-gtst-parts-for-sale/
Forgot to add
R34 GTR
Oem intercooler $200
Oem bov's and all piping $200
All intercooler hoses $50
R32/33 GTR
Ignitor, painted back with fins sanded back a little for looks $100
Edited by Gts-t
Hey mate,
Is the boot lining actually complete? Seems to be missing the little door on the left for the jack and a piece off the right side trim too?
Cheers
Shit your right Jimmy, its not complete :( Whats in the picture is what i have, its been so long since ive looked inside the boot of a R32 thats not stripped i completely missed this. Ill see if i can find the other bits but I'm pretty sure they are long gone.
GTR
R32 gtr ecu $100
R33 gtr oem dump pipes $25
R32/33 gtr tps $50
R32/33 gtr CAS $100
R33 gtr alternator $100
R33 gtr complete cold side, inlet manifold, throttle bodies, plenum etc $450
R34 GTR
R32 GTST
Boot lid $150
Type M brake calipers, front and rear $350
MISC
HKS super hybrid panel air filter, less than 200km use, suits all rb air boxes, as new $20
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
