Vehicle from dealer with a dodgy RWC
Hi everyone!
Just need some help. I've recently purchased a vehicle from a dealer with a dodgy rwc. The dealer sais that the rwc is fine. But I've noticed a huge oil leak in a few days after i bought the car, and some other issues as well. I 've booked a RACV check for this monday and had a conversation to a dealer regarding that. But the dealer seems not really interested to fix the problem. So my question is, where should I forward the RACV check report so they could help me? At the time when the RACV report will be done it will be 10 working days as the rwc has been issued by the dealer. There should be some government organisation which is monitoring such things. Pls let me know if someone knows. Thanks!
Edited by 24Andre
https://www.sau.com.au/forums/topic/470611-vehicle-from-dealer-witha-dodgy-rwc/
Cheers mate,
Ive recently contacted Vicroads, they told me to send all info regarding this issue on [email protected].
I am writing this just in case if someone else got the same problem and doesn't know what to do.
  • Like 1
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
