is it possible same exhust on NA car will be louder then on Turbo?
definetly is in my opinion. the exhaust on the NA car is louder and drones. iv'e never heard the droning noise in the turbo, it mite be loud but doesn't drone. its the drone noise which is killing me atm. weird, from say 2000-3000rpm it will drone at constant speeds, if i hold it at 4000+rpm there is no drone and sounds quite nice.
thanks MegaGTS4, i will be going to exhaust place on friday and asking for a chambered resonator, now hopefully i'll sound like i know what i'm talking about and don't get ripped off!
thanks for the help everyone.
Turbos quieten the exhaust a lot. The passageway in the snail of the exhaust housing tapers down to a small slot. The exhaust gas speeds up to very high speed to drive the turbine.
The restriction in the exhaust housing tends to smooth the exhaust flow, and this will greatly reduce the noise level.
Droning is caused by a resonance in the full length of the exhaust pipe. Pressure waves move back and forth along the pipe, and at certain speeds can build up to a deafening level. Large diameter pipes are far worse because the sound travels more easily down the centre of the pipe.
Small bore pipes offer a pressue drop, and this, along with pipe friction dissipates the sound down the pipe. It dies away going in both directions and cannot build up in amplitude to create the deafening drone.
There are several ways to overcome this problem, but chief among them are absorbtion, and decoupling sections of pipe to create sound traps.
Absorbtion is the primary function of the muffler. Fibreglass or steel wool within the muffler absorb the sound by converting the pressure waves to frictional heat. This does not work too well with straight through mufflers and large diameter pipes, because the sound goes straight down the middle without much absorbtion effect.
Decoupling sections of pipe is achieved by placing one or more chambers along the pipe. These chambers are usually within, and part of the mufflers construction.
What happens is a pressure wave travels along the pipe, and when it reaches a chamber the wave tends to spread out to fill the large volume. Some of the wave is reflected back, some is dissipated in filling the chamber, and some carries on down the pipe, but reduced in strength.
If the chamber volume is large enough compared to pipe volume, and if the chamber is perhaps half way down the pipe, then the two sections of pipe will behave independantly. They are decoupled, and will tend to drone at their own resonant period.
If you are really clever, or fortunate, the two separate pipe resonances can fight each other and further reduce the sound.
Mega GTS4 is spot on with his advice, but this type of muffler does not work properly if placed right at the back. It must be mounted somewhere near the middle, or towards the front.
Turtle, this may sound a little weird, but I had the same problem and fixed it by going down to spotlight and buying some 2" thick quilting material and some spray glue. I then cut several pieces to size and stuck them everywhere I could in the boot that was out of sight. This actually helped immensley and was quite cheep - about $15 all up. The end result was no more headaches. The exhaust is still loud but not deafening. Just hope the EPA don't find me :D
Steve
I'm having the exact opposite with my car......i want it louder!
hehe, believe me GTR-80Y, quiet is all good!
Steve, that sounds like a cheap option :D but i want to reduce the noise outside as well. friends tell me they can hear me leaving and know exactly where i am till the next block.
I know the feeling. The trouble is, that once they hear you coming, and focus their beady little eyes on you, you are stuffed.
When they have you pulled over on the side of the road, you are going to get the full works. Licence check, rego check, tyres, ground clearance, blow into this driver, - they are going to find something, even if its total BS.
Best just to glide past them in complete silence, and let the guy behind in the rice mobile, get done instead. Hehe.
well I got done once on Freeway due to loud exhust... I told cop this is BS...
but he gave me yellow...
so I went to pits all got claeared and got me self modification Permit.
so next time cop say anything about the modofication? then I shove me permits to their ass
:lol:
cheers
Joe
I have a full three inch system that is quieter than stock (true) under light load, or when you rev it up in neutral. On the freeway all I can hear is wind and tyre roar at 100Kmh.
Flat out it is fairly loud, but probably still legal though. I have been sitting on zero points now for three and a half years.
A month ago there was a police car going in the other direction, In the rear view mirror I saw him do a U turn and come up fast behind me, I eased off (using the handbrake) and was just below the speed limit.
He put on the flashing lights and pulled me over. Walked right around the car, it looks completely stock, and told me my front numberplate was illegible. He was right. Cost me $24 for a pair of nice shiny new plates, which make the car look better anyhow.
Now if he had looked under the car, or under the bonnet, he would have put me off the road instantly for illegal modifications. My car is fairly radical, but because it is quiet and looks stock I can get away with it.
My mate had a RX4 with a 13B NA engine. This car had the maddest exhaust I've ever seen. Twin 3.5" dumps from the engine right the way through, There were two hot dogs per outlet so 4 in total, this went back into a truck muffler with twin outlets. I've never heard anything louder. Outside it was loud, inside wasn't too bad btu what do you expect from that setup...
That car was fast. 12K RPM redline from a professionally built setup...
ok, just came back from exhaust place. they weren't very helpful :mad: kept telling me to take this exhaust off and they'll make a custom one for me. man, i can't afford that, then i just wasted all my money on this exhaust. sheesh.
gonna wait till monday now, and goto Dandy exhaust, heard they were pretty decent.
btw, if anyone wants to swap their current muffler for a bigger size one then let me know. so any turbo guys out there with a 2.5" oval shaped or something muffler and want the apexi n1 style chrome with 5" tip let me know.
cheers
From your last post I gather you plan to replace the rear muffler.
I would leave it right where it is for the moment, and add a second chambered muffler halfway down the pipe.
Putting an offset chambered muffler right at the back is not going to give you the sound reduction you need. It will work far better closer to the engine.
You can try it right at the back, but I dont think you are going to be happy with it.
yep, i'm thinking about getting rid of the muffler, thats what the guy kept telling me the problem is.
he said, we could change the resonator, but "its like chopping ur leg off wen u have a headace", its not going to fix the problem.
but really, i'd prefer not to change it and just put in a chambered resonator as suggested by ppl here. plus i don't have money to do that.
i think maybe he was trying to get more money outta me by making me change the full exhaust hehe.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
