Here's a list of the NSW metro Police, find which repeaters are closest to you and try them out.
http://www.scanaustralia.bigpondhosting.co...sw/vkguhfm.html
NSW regional
http://www.scanaustralia.bigpondhosting.co...sw/vkguhfc.html
my understanding is that scanning and listening to police is illegal??
i thought that "broadcasting" po1ice was illegal, but listening in private was ok....like, if u walk down the street with it on, thats illegal. (or if u rent a movie, u can watch it @ home with a grp of mates, but cant show it in public)
not 2 sure where i heard that tho, or how reputable it is
If it was illegal, they wouldn't be able to sell scanners :D
As long as you're not doing anything illegal with the information you hear, then there's not a problem... however, if you were driving around with it in the car with it turned on, Police would take issue with you over it.
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
