I used to have starting issues in that the car used to struggle to get up to the idling rpm. This used to be resolved with a simple jab on the accelerator to bring it up to the right rpm - no issues.
I then fixed this issue by replacing my fuel pump to a walbro 225L p/h and it's been fine since until recently.
I had my alternator die about two weeks ago and it got replaced last week. Now one thing I've noticed is that the starting issue has re-emerged. The other thing is that my voltage sits at around 12V until I rev it up to around 2,500rpm. The "normal" voltage I read is around 13.5V or so (this is reading through my HKS Type-1 turbo timer which has a voltage readout). I'll check the voltage at the battery itself (multimeter has a blown fuse) this afternoon.
Shouldn't the voltage be at 14.4V when the engine's on?
What could be causing the starting issue? Not enough power?
This is in a RB20DET btw.
https://www.sau.com.au/forums/topic/47231-starting-electrical-power-issue-r32/
  • 3 weeks later...
I've read a few threads about RB engines not starting too well, needing alot of cranking and when they do turn over they barley idle at 4-500rpm and need a stab on the accel. to be bought up to proper idle speed. I've recently fixed this problem on my 33 with a new set of coil packs. The motor starts normally now so it might be worth checking your coil packs if you have this problem.
-rb25
Ive just replaced my engine, and the went to start for the first time after i picked it up...wouldnt crank...turns out the positive wire off the battery isnt big enough to crank over the new motor...Everyone seems to replace the earth leads off the car, but never talk of the positive wires...Beef up them (cost would be fa) then let us know how good the car cranks over :)
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
