Hi all. I have for sale a plazmaman plenum with a 66mm throttle body and plazmaman b.o.v. fits the rb neo, all in black, no scratches or marks still in perfect near new condition, $1500 for the lot.
Also i have a genuine sard fuel rail and a set of sard 740cc injectors, in great condition $450..
Can do the lot in a package for $1800.. prices are firm.. located in geelong Victoria and i can post at your expensive. Plenum currently all taped up so it dont get marks when fitting..ad_1510872632383.jpg.1522642557571.jpeg1522642577114.jpeg
https://www.sau.com.au/forums/topic/473675-neo-plazmaman-plenum-tb-bov/
## If sold in 1 lot for $1500 im willing to give the lower section so just bolt on and away you go..20180407_183836.jpg
Package will include all in this pic plus injectors, fuel rail & b.o.v. Bargain price if you look to see what all is new and all this is still like new. Thank you
Injectors-SOLD..
bov-SOLD
NEW PRICING ON REST...
I SORT OF STUFFED UP WHEN I FIRST LISTED.. I DO APPOLAGIZE AND DID SELL OTHERS AT LISTED PRICES BEFORE I REALIZED.. i hope you can understand.. thank you
Plenum-$750...
T/Body-$350...
F/Rail-$100
