Car runs fine until it gets some boost then I get what sounds like a high tension short. I've got LS2 coils and use the factory boots. Has worked fine in the past. I've replaced plugs, cleaned surfaces etc. Other than getting into a dark dyno room, is there some other way to find which coil is shorting? Maybe dust the area fingerprint style, then look for burnt dust?
Buy new coil, HT lead and boots and swap known good item in with each coil sequentially each time you take it for a drive.
Somewhere between drive 1 and 6 should have been able to isolate the issue further.
Continue troubleshooting as necessary.
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
    • I'm going to guess, likely headunit, and the twin cable likely went to an amp as a remote turn on feed.
