Hi sau
up forsale is my 1989 mspec r32 gtst ?.
Had the car for about 7 years and have spent allot of money on her.
it has a rb25 series 1 motor
*cp pistons
*billet oil pump gears
*greddy plenum
*splitfire coil packs
*800cc injectors
*Garrett 3582r polished
*50 millimeter external gate to atmosphere.
*locked diff bit shagged.
*exedy clucth
*ksport coil overs
*adjusted able rear camber arms
* 25 box
*2 piece tail shaft
*drift tek wheels front 8.5 rear 9.5
*gtr seats front
* gtr bonnet
*gizmo electronic boost controller
*power fc with lc hand controller
*walbro fuel pump ( could use a bigger pump for powers)
The car isnt the making big power as i lost the passion for it. spend some money on a good fuel system and diff she'll tear your face off.  Has allot of goodies in her, ready for someone to enjoy or make it a beast.
paint is average needs a spray in my opinion.
these 32 are hard to find these days especially a perfect on and mine is far from perfect but potentially could be!
motor has about 20000km on it
has rego and for $9500 you will own it.
0four3one4three48zer08
any q's msg me.
Regards Gus
Edited by gus's r32rb25det
oil pump gears a billet
  • Like 1
https://www.sau.com.au/forums/topic/475808-r32-forsale/
  • 1 month later...
