hello, my name is nick and i own a 88 tx5 turbo. i have recently purchased a complete turbo setup for my car and it consists of the standard manifold with an adaptor plate and an r33 gtr turbo, 35mm hks external wastegate with screamer pipe and a 2.5inch dump pipe. the turbo is significantly bigger than my old sotcker turbo, but i dont know much about them.
i have a few questions (i done a quick search, and couldnt find what i was after).
firstly, what is the sizing of a gtr turbo (ie: how many cfm's does it flow? is it equivalent to a t28, t3 etc?).
secondly, is it a ball bearing centre? if not what type of bearings does it use?
and finally does this turbo use a ceramic exhaust wheel? what is a safe boost level on it?
sorry about all the questions, but i dont know much about these particular turbos.
regards, nick.
https://www.sau.com.au/forums/topic/47733-r33-gtr-turbo-question/
in response as to why it has been converted to an external gate: i would say this would be due to spacing issues because of how the turbo is mounted on the manifold.i think it is on the opposite side of the engine as to how it would be mounted on a gt-r. i dont think an internal wastegate actuator would fit in there.
thanks for the clarification on sizing. so technically, a gts-t turbo would be an upgrade.
i plan to run 10psi on it until i upgrade my intercooler and get a larger fuel pump. now i know how much i can turn the boost up. could i possibly get away with 15psi?
regards, nick.
regards, nick.
You must be kidding right??
A internal gate actuator is tiny compared to an external gate and it would be 100 times easier to make a little actuator fit rather than a whole external gate and piping etc it needs to work.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
