Nissan 200sx S14 S2 1997 Aus delivered by Nissan Australia (ADM) - Aka Silvia
Jungle Green - Resprayed about 9 years ago, body and paint in immaculate condition
Full ground up rebuild and stroker kit done by Racepace in Bayswater - Only done about 1000km since.
I had a pretty nasty car accident a few months ago and have just lost the passion for the car scene. Car is sitting there being driven to and from the carwash.
Over 40k in parts receipts
Nitto SR20 2.2 Stroker kit
Full Billet Counterweighted crank
Nitto pistons
H beam rods
Tomei head gasket
RPM custom main and big end bearings
RPM circuit short motor build
RPM circuit head rebuild
New Nissan timing chain, guides, tensioner and bolts
ARP Cylinder head stud kit
ARP Main stud kit
1000cc Side feed Injectors
Tomei vat delete cam gear
Power FC with hand controller
Garret 2871r turbo with custom external wastegate and V band dump
Waldron 460lph intank fuel pump
Cusco engine mount
Aeroflow sump
Plazmaman SR20 billet main girdle
Genuine Nissan water pump
Genuine Nissan oil pump
Aeroflow high volume oil pan
Nissan exhaust valve guide set
Full 3” custom exhaust with Varex muffler
BC coilovers
Front and rear strut braces
Front and rear toe arms
Hardrace front and rear UCA
Rear subframe lock kit
Nissan outer tie rod end
Rays TE37SL Black Edition II
18 x 9.5 +21 front
18 x 10.5 +21 rear
Nitto NT05 tyres all round - 245/40 front and 265/35 rear (pretty much brand new)
ARP stud kit front and rear
DBA4000 slotted front discs
Winmax W3 front and rear pads
Nissan Z32 5 speed gearbox
Alpha omega adaptor kit with short shifter
DCS Twin plate clutch
R32 GTR 4.1 LSD Diff with Nismo centre
GTR rear driveshafts
Custom one piece tailshaft
JDM Front grill
JDM S1 rear bar
Roof lip spoiler
Interior is very clean and kept in original condition
GFB 2 boost controller
Blitz turbo timer
Datsun steering wheel
Boost gauge
CD player with 2x Pioneer 10” subs
Car currently makes 300kw @ wheels on E85
I also have a BRAND NEW Borg Warner EFR 8374 that I was going to put on the car.
This car was built with huge power in mind. If you know SR’s, you’ll know how capable the Nitto 2.2 really is.
I’ve poured a lot of money into the motor and driveline as my ultimate goal was a reliable 500kw. Everything is there if you decide to go that way, I just never quite got around to finishing it.
As it is now, it’s still a huge amount of fun and has plenty of power with the 2871, but the sky is the limit with the motor that’s in it now.
I also have some standard parts that will come with the car.
I know I’ll regret it and I’ll some day get back into an S chassis but for now I’d rather see it go to someone that will bring it up to it’s truest potential
Car is currently insured for $66,200 with RACV.
$31,000 with the EFR
or
$28,000 without
No test pilots. Car will only be driven by serious buyers with a deposit.
*KMKAZI plates will not come with the car
  • Like 1
https://www.sau.com.au/forums/topic/477450-s14-200sx-s2-sr20-nitto-22-stroker/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
