Hey guys I’m in the market for a manual GTT coupe
must have a clean title, rust free, straight chassis/rails, under 150XXXkm, prefer a tastefully modified example rather than stock, ideally something already pushing 250-300kw
have cash ready
please shoot me a pm if you are considering selling
Thankyou
https://www.sau.com.au/forums/topic/477480-wtb-r34-gtt-manual-coupe/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
