OKAY.
Anybody in Melbourne who really really needs their guides today, please call me.
I have pulled a favour at the subbies and he's cutting the panels for me right now.
Daz and Matt are coming to pick them up this arvo and if anybody needs one, for circuit racing or Auto Salon, please let me know ASAP so I can bend them up this arvo.
0419 101 639
Call me if you need to.
BASS OUT
  • Replies 175
I can wait til next week - no need to bust chops, I am sure my car will survive.
But if its not a hassle I can also pick up this weekend - but its not urgent for me mate :D
Its up to you Pete!
Ok after breaking two ring spanners I managed to get my guide on. Fits very nicely and looks great. Sidchrome tools definitely worth the price as a side note.
Will see what sort of temp improvements I see over the weekend.
Thanks.
NJR
I'm glad you like it. I think they all came up quite well.
Especially since I trial fitted every single guide to my car.
Anyway, take a photo for the guys and post it up.
Also, could you please give me a trader rating. Thanks.
And for those with Standard Bars and AFtermarket bars, here's the story.
The subbie who are cutting the bars were going to do them Friday afternoon, but as Friday's go, they didn't end up doing them.
They will be cut early Monday, and I expect to be able to ship them by Tuesday afternoon.
Sorry to Matt who drove all the way out to collect them.
Let you know Monday when they are going to be ready.
BASS OUT
NISMO BAR PEOPLE
P.S. I will also be playing around with my nismo guide.
You can see on the guides you have that there is a section which ic cut out but unbent.
This is for later modification to force more air into the intake.
I didn't want to mees around with yours as I have a lot of playing to do with mine before I can finish it. Also, there's a good chanch that when I try to bend mine it will kink somewhere and I didn't want to damage yours.
When I do complete the mods, I will take heaps of photos for you all.
BASS OUT
:D
Didn't fit. Well after buggerising around for a bit chopping off two little bits that were stopping the thing fitting on, then accidently cross threading one of the bolts (which stuffed the bracket not the bolt) I went to shut the bonnet and it wouldn't shut. I even tried sitting on it but no go.
It seems my bonnet has some bits on it that yours doesn't Bass. Not sure that I want to pull them off.
Serious?
Can you take some photos of the bit that your bonnet has please?
What little bits were stopping it going on?
I took some photos but haven't had a chance to up load them yet. Will do that tonight when I get home.
It's probably easier if I circle the bits on the photo before I post it tonight.
SHIT. I did't realise that his was a four dorr, but I'm not sure there would be any difference.
Having said that, I do remember a thread about ylwgtr's car and that he had a four door radiator support or something.....
Maybe there is a little difference.
Bugger.
4 door shouldn't be any different from the firewall forward.
http://www.skylinesaustralia.com/forums/at...achmentid=22571
see where you have put the foam stuff... I have these rubber flaps that hang down a little bit.
Ah, right.
Maybe they are factory attempts at the same idea??
If there are flaps there, it forces air to be pushed down underneath the radiator support.....
I guess.
does the nissan FAST software show car components... if it does,, it might show all the rubber under the bonnet,,
i don't have any rubber flaps!! and mine is a series II ,, talk about cost cutting bye nissan.. can someone post pics of their bonnet,, i might go to nissan and get some rubber flaps for the bonnet,, just need to know how many there are meant to be, and location,,
atleast i have the bonnet lining,, sheesh!!
afro
Ok here is two pictures. The red circles are where I had to modify. The middle one is because once the guide was on I couldn't get a finger under the latch to open it. The one on the right is not the same as the bit on the far left as it should have been but that's no big deal, I just cut it off with a hacksaw.
The pic of the bonnet is self explanatory really. The rubber flaps are held on with a bit of metal and so when you add the bit of rubber attached to the bonnet to the metal holding it on to the rubber that normally hangs down but can't because of the air guide it's all about 2cm thick.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
