1993 r33 gtst auto silver/grey colour
125.000klm's
18"black chrome wheels
alarm with central locking not very old worth($450)
pioneer cd player
sports steering wheel
pedders lowered springs
front mount intercooler
3"exhaust
pod filter
turbosmart bov
wolf plug in ecu
walbro 500hp fuel pump (new)
malpassi rising rate pressure reg (new)
hks gt2535 b/b turbo running 15 psi
car has 220rwkw's i have dyno sheet
anyone interested send a pm thanks
$20000 or $19500 no rwc
factory type m front bar now fitted (not shown)
car also has personalised plates which are not included(not shown in pic)
https://www.sau.com.au/forums/topic/47801-r33-skyline/
No...The car is mine it is a Holden Barina SXI 2003, RED, 5 SPEED MANUAL, Holden Alloys, power steer, Air con, Power windows, european design not like the older ones. Balance of new car warranty about 3 years. It is woth $14,000 and i have $3,500
https://www.sau.com.au/forums/topic/47801-r33-skyline/#findComment-980337
Wel the Holden Barina's now are $13,990 plus $1,800 to $2,000 for the on roads then $1,000 for the Holden By design Alloys mine has so thats $17,000 instead though Im talking about doig a trade with you and mine has 15,500kms,as good as a NEW one Plus giving you 4,000 at this stage. To me thats sounds good deal.
Thanks!
https://www.sau.com.au/forums/topic/47801-r33-skyline/#findComment-980796
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
