1993 r33 gtst auto silver/grey colour
125.000klm's
18"black chrome wheels
alarm with central locking not very old worth($450)
pioneer cd player
sports steering wheel
pedders lowered springs
front mount intercooler
3"exhaust
pod filter
turbosmart bov
wolf plug in ecu
walbro 500hp fuel pump (new)
malpassi rising rate pressure reg (new)
hks gt2535 b/b turbo running 15 psi
car has 220rwkw's i have dyno sheet
anyone interested send a pm thanks
$20000 or $19500 no rwc
factory type m front bar now fitted (not shown)
car also has personalised plates which are not included(not shown in pic)
https://www.sau.com.au/forums/topic/47801-r33-skyline/
No...The car is mine it is a Holden Barina SXI 2003, RED, 5 SPEED MANUAL, Holden Alloys, power steer, Air con, Power windows, european design not like the older ones. Balance of new car warranty about 3 years. It is woth $14,000 and i have $3,500
https://www.sau.com.au/forums/topic/47801-r33-skyline/#findComment-980337
Wel the Holden Barina's now are $13,990 plus $1,800 to $2,000 for the on roads then $1,000 for the Holden By design Alloys mine has so thats $17,000 instead though Im talking about doig a trade with you and mine has 15,500kms,as good as a NEW one Plus giving you 4,000 at this stage. To me thats sounds good deal.
Thanks!
https://www.sau.com.au/forums/topic/47801-r33-skyline/#findComment-980796
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
