Hi All,
I have a GTR R32 Front Bumper for sale. Price $350 AUD
It is primed and ready for paint (just need to wet sand with 800grid sandpaper) and apply paint.
Comes without the bumper vents. Will upload pictures this afternoon.
Located in Perth, WA. I can also post it at buyers expense.
https://www.sau.com.au/forums/topic/479605-gtr-r32-front-bumper/
