you can get red EL as well just a matter of asking for it I guess, might cost a lil more... if you just wanted red dials, change the lights in your cluster to red LEDs with resistors... should look stock but instead of white/yellowish you'll have bright red
https://www.sau.com.au/forums/topic/48109-illumiated-dials/#findComment-971853
the way EL works is a layer of luminescant is made to vibrate at a certain frequency, change the current and you'll change the frequency. Blue/Green is the easiest to make, but if you managed to get the luminescant to vibrate at the lower (or was it higher) frequency then it'll give out a red light. Of course the life of a Red EL is shorter than a blue one.
https://www.sau.com.au/forums/topic/48109-illumiated-dials/#findComment-971880
if you get a resistor with an LED you should be able to trick it up to the same voltage as a globe and wiggle it into the socket - bright LEDs will have that nice rice effect.
if you just want the basic EL kit.. www.modyourcar.com.au and a few places like that have them.. hideously overpriced ($250 or so) for what they are - but hey that is rice for you.
I have a spare cluster I have been playing with, but I still for the life of me can't work out how to get the needles off! I remember on my r31 cluster its very similar, and you just kind of pop them off.. but on the r32 cluster there seems a lot of resistance and I feel that if i pop the needle off its going to rip the spring or whatever is behind it out too ??
Is there a special trick to it? or do you just have to use a bit of careful force.
https://www.sau.com.au/forums/topic/48109-illumiated-dials/#findComment-972327
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
