hey peeps
need to get my car atleast 40mm closer to the ground and from what i been told, the shocks would just die if i tried putting lower springs in. was told that they usually dont drop the car much anyway, so i guess coilovers are the way to go ....
anyone have for sale or know where i can get a reasonably priced set of adjustable coil overs?
cheers
shannon
https://www.sau.com.au/forums/topic/4816-looking-for-r33-coilovers/
heya clint,
thats what ive heard, but to acheive the ride height i want ,i dont think i will be able to just use springs?
has anyone used the whiteline springs with the bilstein shocks to get a drop of 40 (ish) mm ?
or does anyone know of another way of acheiving that kinda ride height ?
also i been told im gonna have to get a set of wheel spacers for the wheels i want, has anyone used these and if so anyone had any problems with em?
are they just needed on the front usually or the rear aswell?
so many questions......
thanks
shannon
With the bilsteins you can adjust the height by machining groves in the shocks ( thats what I have done).
You can get two types of wheel spacers, ones that bolt on and others that slide over the studs, these will require longer studs.
the ones that bolt on are better but you only need them if you need 25mm or so spacing.
If you only need 10mm or so slip on ones will be fine, I have used both on a mates car.
your a wealth of information mate!!
cheers ;)
where did you get your shocks machined / suspension done? and how much lower is your car?
any suggestions on where to get the spacers done? im more than likely gonna get em from jms. do you know if you usually need to have em front and back ?
thanks again
shannon
I`ve got my car to sit pretty low.I`ve got a set of GAB coil/overs with damp/rebound adjustment.Together with Whiteline bushes throughout and swaybars aswell the car stick to the tar like.....
The Japanese coilovers are rock solid and you do feel every bump so be warned.
Wheel spacers-what for?
I`ve heard to many stories about them to never use them!
Matt
heya bugalugs....
ive got my eye on a set of tein coil overs , hopefully they should do the trick. im not too fussed about the "stiffer" ride, but i guess thats easy to say now, ask me again in a week ...lol
do you know roughly how much of a drop you got with your coilovers? any pics i could check out?
i been told that the wheels im getting will rub on the brakes, so im gonna be needing wheel spacers? they didnt have any there to try, but if i can get them on with a spacer i guess its all good.
what have you heard that turned you off em?
cheers
shannon
You can really slam the car with coilovers but then you have camber problems.I dont mind having plenty of front camber but the rears can be a problem if you want to put power to the ground.The other thing is tyre wear.Thats why i run the camber kit from Whiteline just to get rid of some camber on the rear.I have no pics to put up.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
