I’m having an issue with my R34. I left my headlights on and the car battery died. I went out to jump start the car and left my headlights on. It obviously didn’t start, so I turned my headlights off and started the car again. But now my headlights don’t seem to turn on at all, and only 1 of my high beams work. I checked all the fuses in the engine bay and they all are good. I thought maybe the bulbs somehow got blown but I checked for continuity and they seem okay. I next checked the wires connecting to the bulb for continuity and they seem fine too. I’m wondering if maybe I somehow fried the turning signal stalk by starting the car while the lights were still on.
Any ideas of what might be happening?
thanks in advance!
https://www.sau.com.au/forums/topic/481841-low-beams-not-turning-on-r34/
Get the wiring diagram out. Remove the headlight switch loom plug and probe for where the power is supposed to be. That will tell you if you've missed something upstream (like the real fuse that you should have checked). Probe for continuity across switch terminals that are supposed to be continuous when turned on. Plug it back and in and probe to see if power turns up on the output side of the switch.
Etc etc etc.
Somewhere there will be a wire that is broken or burnt, or a fuse that is is open, or a switch that has melted or burnt in the wrong position. The wiring diagram shows you what you need to be looking for, and where.
I'm still a little confused about this.... I removed my turn signal switch from my car and I'm trying to test if it's good or not. If I understand the diagram correctly, in the Lighting SW area of the diagram, I set my switch to 1ST position and check the pins for continuity. So I put my multimeter on Pin 1 and Pin 9 and set my multimeter to resistance. I test the pins but it it seems like there is no continuity there.
Am I reading this diagram wrong? What do the Hi/Lo/P stuff mean?
Not sure if it makes a difference but I don't have an AUTO mode on my switch. My switch also doesn't have all the same pins that are shown in the diagram. I've attached an image of the wiring diagram for convenience.
Wiring Diagram
I'm sorta a noob at electrical so anything helps.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
