Hey guys its just past mid 2021 i hope all are good..so ive had my 33gts4 since 2009 got for me 21st i moved to brizzy i 2011 and left it at my olds back in nz its been sitting most the time and with the market the way it is im looking at bringing it over to qld..its completely stock. nothing done to it at all has a bit of rust in spare wheel well and a little surface rust on the strut towers which is surprising ive been reading through all the threads any info anyone wants to share would be great cheers guys
  • Like 1
https://www.sau.com.au/forums/topic/482824-kozor33gts4/
If it was me, i would just clean the rust off, treat it and then spray with fresh paint... its only surface rust, if you treat it now it should avoid any larger issues.
Although usually when you see surface rust on the towers, check under the car as it may be rusting from the bottom and only just showing on the strut tops.
https://www.sau.com.au/forums/topic/482824-kozor33gts4/#findComment-7955903
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
