Hi guys,
I have a '97 R33 GTR with HKS GT2530 turbos. Earlier tonight I was having some fun driving it when I noticed that it started to feel a little "sluggish". I then noticed that the peak boost it had achieved in my last run was only 1.2 bar instead of the 1.5 bar I was getting earlier. I quickly pulled the car over and smoke was absolutely pouring out the exhaust. It was difficult to see in the dark but it looked like the smoke was white in colour. I lifted the bonnet could hear water or fluid bubbling in the radiator (don't know if that means anything but I haven't noticed that before). I also noticed a couple of strange sounds when I noticed the car was sluggish but I can't remember what they sounded like but only remember hearing something out of the usual. The car still runs but is now is running very badly so I just got it towed.
Does this sound like a blown turbo? If so can it be repaired or what's involved getting it fixed. If it doesn't sound like a turbo then any ideas on what has happened.
As I'm sure you can tell, I have very limited mechanical knowledge but am very concerned. I hope someone can help.
Thanks.
https://www.sau.com.au/forums/topic/48360-help-please/
To me the coolant bubbling in the radiator sounds like you may have overheated the car and blown a headgasket, which would cause the white smoke and performance problems the cars now having. Possibly get that checked out. Did you notice if the water (or even oil) temp was abnormal?
https://www.sau.com.au/forums/topic/48360-help-please/#findComment-973027
No I didn'y think to look at the temp guages unfortunately. It was a progressive event that took about 2 minutes in that firstly everything was fine then I stopped then accelerated very hard and noticed performance was quite poor compared to 5 minutes earlier, I then backed off and noticed that it only made 1.2 bar boost, I then cruised for about 1km and then noticed the engine did not sound right when I accelerated, I did not notice smoke at this point but then it was just pouring out the exhaust.
If it's the head gasket, is this a big deal? Does it take long for a mechanic to fix or cost much?
Thanks again!
https://www.sau.com.au/forums/topic/48360-help-please/#findComment-973044
Aha! I think you're right. Just thinking about it now, I was running the car quite hard with acceleration and at high speeds and then pulled over for 5 mins and just let the car idle while I was talking to a mate. At this point everything was fine, then jump in car, accelerate hard and find poor power and so on.
So probably after giving the car a hard run, then pulling over and without airflow through the engine bay it was overheating while I left it idleing. Does this sound like it could be the case?
And further again about a head gasket, is it a difficult job to fix/replace and would it take long for a mechanic to do?
Thanks.
https://www.sau.com.au/forums/topic/48360-help-please/#findComment-973067
head gasket on a gtr? maybe $2000. fair bit of work to get the head off. On all of my past performance cars i have installed a cheap and money saving device. Its a bloody big siren that is wired into the water temperature, so that when it starts to overheat for whatever reason the thing goes off and scares the crap out of you. Sometimes on the track its hard to check your guages when you are racing.
Was there any coolant under the car? Did you notice the cars acceleration do a quick stutter or just do a big miss for a second? I have noticed my cars do this before when a radiator hose blows.
https://www.sau.com.au/forums/topic/48360-help-please/#findComment-974906
  • 3 weeks later...
i have a simialar problem in my R32 GTS4 - no performance loss, but after a drive in the hot wheather after i turn the car off the coolant overflow tank and almost full and is making a bubbling noise. they is not leaks, not smaoke out of the exhaust, temp gauge doesn't go up at all, stays at halfway. i also had a water pump replaced about 4 - 5 months ago and the guys only put water back in, about a week later i drained the radiator and filled it with coolant. could the problem just be that the water is overheating.
p.s. colour of water is green and no signs of oil or anything. also no water in engine oil.
any help would be great
https://www.sau.com.au/forums/topic/48360-help-please/#findComment-994327
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
