Hi.
About 12 months ago i purchased a 2001 Toyota townace that was fitted with the mongoose m60 immobiliser unit.
The unit was working okay for around 6 months with the only exception being the passenger side door wouldn't lock/unlock via the remote. This had no effect on the start up of the car.
I lost the original key to the car and as this was a second vehicle of mine i didnt get a locksmith to cut a new key straight away and the car sat in the driveway for around 3 months before I eventually had a locksmith come and cut a key.
The battery went flat in this period of time but after he cut the key all it needed wad a jumpstart and the car was working again.. until I reached first destination and switched car off when I began having issues with the car starting (engine would crank but felt as though fuel pump wasn't allowing car to properly start)
After a jumpstart again, car started and I drove home without any issue.
Following day I couldn't start car at all and for next week I drained battery trying to get the engine to keep running after startup. Called locksmith who insisted over phone that my battery needed replacing.
Put battery charger on overnight and cat started & drove a couple times the next day before car wouldn't restart 20km away from home.
Drained battery again trying to turn car over before Replacing battery, terminals etc. And now the engine won't even crank yet electrics work fine.
Eventually towed it home with straps and even roll start attempts would prove that immobiliser must be the issue and I'm guessing that replacing battery may have caused engine to not even crank after doing so.
The car was sold to me with the mongoose info / manual but no pin code to be found. Contacted previous owner before the last owner and found nothing.
My question is am I better off removing the mongoose immobiliser/alarm system altogether? And if so  how?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
