Hi can anyone tell me if the Q45afm are a good afm to use or would it be better fo me to use a z32 AFM.
Reason being there is one for sale here on the forums and i want to know its benifit over the more commenly used z32afm.
What is installation like for a reasonably experienced diyer.
I am chaseing just under 400hp at the flywheel.
For an S1 R33 RB25DET.
https://www.sau.com.au/forums/topic/48450-q45-afm-qs/
