Some info to share after a bit of research:
The updated Nissan OEM part number for my 2007, V36 350GT is 214934GA0A (old part number is 21493EH10A) - Circa $100 to $200 AUD dependant on brand/quality
The interchangeable part is (as seen here: https://www.aliexpress.com/item/1005004459559212.html) : 1355A408 (Cooling Fan Control Module For Mitsubishi Lancer 02-06 ) - Circa $30-40 (AUssie stock and free delivery) example : https://www.ebay.com.au/itm/153550014872
Both these parts look identical, however I'll be purchasing the MIsubishi part number. The OEMs supplier is the same for Nissan/Infiniti/Mitsubishi - Calsonic Kansei part# 21493
FYI My fan controller needs changing as the fan is always on.
Happy DIY-ing folks!
Edited by Elcid
Adding Calsonic part #
  • Thanks 1
Following this as Im having the same issue at the moment. I didn't realise they were on for so long, now one of the motors squeaks as it winds down when turning the car off. I was looking at one from a 2011 wreck, but the yard is taking forever to give me a price lol.
Lol, will keep you posted mate.
If I recall right the squeaks can be solved the using a long straw nozzled spray grease , spraying straight into the fan motor.
I dont know where we are talking about or followed the thread, but if its electrical, PTFE lubricant may be better. You can get it from JayCar.
Was just gonna wd40 it when I go to replace the fcm :P
Note, WD40 is not a lubricant. It is "Water Displacement 40". It will also dissolve grease and fall away & the area will "dry up". It just happens to provide a very temporary apparent lubricant action.
I personally think it evil as it gives an immediate impression something is lubricated, but it will actually make it even worse in the long run. I now use the PTFE spray (tiny plastic marbles) where most would use WD40.
Edited by Vee37
  • Like 1
Thanks a lot for that info, I had no idea. Did a quick search and WD40 do a ptfe. Would this be suitable?
https://www.bunnings.com.au/wd-40-150g-specialist-anti-friction-dry-ptfe-lubricant_p6100410
I dont know. I haven't really followed the thread and thus dont understand the use, I just have a knee jerk reaction to people using WD40, and had no idea WD40 did a PTFE one or ever used it. My can from JayCar has lasted me for years, and so is my first and only can. I did buy another can once for someone else who had a temp car with a very squeaky fan belt, and the WD40 he used lasted for 1 drive where as the PTFE went on working.
I originally got this stuff to also use near electricals, which reading the WD40 version, has no mention specifically at bunnings blurb. To be clear, I dont actually know which would be better. However, JayCar is cheaper, specifically meant to work near electronics (ie not conductive) AND you still get more. Also, I just notice it does explicitly suggest use in automotive cases.
https://www.jaycar.com.au/dry-lubricant-spray/p/NA1013?pos=2&queryId=f216ad417d61e2f0f75768df405fb90b&sort=relevance&searchText=lubricant
And to be clear, maybe the grease still might be a better option. I know I use it for my garage Door tracks.
  • Like 1
Hey Awsam,
The replacement worked perfect. Exact hardware match and works well now. No constantly ON fans. Checked when the engine was cold, with (both fans on) and without A/C (fans off) - works well. Will be confirming that the fans turn on when the engine gets hot too. Should be fine, will report back if not.
Use this vid for detail of removal process :
Images of the part attached. The unmarked one is the new one. I bought this : https://www.ebay.com.au/itm/144660931416?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=ywpbmkztsqc&sssrc=2349624&ssuid=JqKD_6noRQW&var=&widget_ver=artemis&media=COPY
Happy DIY-ing!
Edited by Elcid
Added photos of part
On 15/05/2023 at 9:06 AM, Elcid said:
Fan turns on perfect! So all good
Just an update. Got that part in, plastic was brittle and one of the clips broke pretty easily. Still went together fine, and my fans are running as they should now
  • 3 months later...
*update* while working on something else, I found that the bottom plug that goes to the Drivers side fan was loose. Left fan was not working. Please ensure you use extra force to push the plug in. Once secure, it will be hard to pull out.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
