This might interest someone... think you need two people??
To redeem your subscription call 1300 656 933 and Quote Reference number: RD/08004 for $26.40 off a subscription to Fast Four plus 4 free issues for your self!! A Total Saving of $58.20.
12 issues per year is Regularly $69.00. Payment for Subscriptions is taken by Credit Card or Cheque.
To ensure delivery of your FREE gift card prior to Father's Day, orders must be received by 28th August, 2004.
Offer available for Australian residents only and ends 30.10.04.
The two subscriptions will run concurrently and must be taken by two separate people
https://www.sau.com.au/forums/topic/48500-discount-fast-fours-subscription/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
