Hey guys i got this slight problem and its starting to give me the shits, when the car is at idle and in neutral, i can hear the heavy duty clutch spinning, when i push the clutch pedal in the noise stops and all i hear is the normal tune of the exhaust..
I've had the car for just about a month now, the dude i bought the car off said he just fitted a heavy duty clutch....
Could it be that its just wearing in or its not fitted correctly..
Anyone experienced this before?
https://www.sau.com.au/forums/topic/48619-clutch-noises-on-rb20det/
Sounds like either the Thrust Bearing or Gearbox Input Shaft Bearing. Either way, if the noise is loud enough to shit you, get it checked out.
  • 1 month later...
It sounds like the thrust bearing in the clutch is screwed, i have seen the problem before especially in r32's is it clunking or just whining, it seems to be different for different clutches, chances are that it wasn't installed properly or he used the one from the old clutch which is getting tired. pm me with which noise it is if you could or tell me if i am right if it has been fixed already. cheers, slippery
Had the same noise in previous rb20, ca18 and current r33 - when you let the clutch out in neutral you have a 'whirring' noise - I allways hear it in my dad's corrigated iron shed where it echoes. Just the g/box input shaft bearings I'd say as long as it's not too loud - after all the shaft/gears are spinning in there. If it happens when the clutch is in it'd be the clutch throw-out bearing. Hope this helps
I have the same noise and a few others, if you just rest your foot on the clutch its worse and then like you said push it in a bit and it goes away. My mate is pretty good with this stuff and he said something just needs to be adjusted, cannot recall what he said but there is to much slack or something like that :D
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
