Guys I have an R32 GTR ('89) – and I have been having problems with the aid con not working properly. From time to time it just shuts off and starts heating for a few minuets- and then seems to sort t self out and start to work again ???
it seems to kast longer if I set the temp to 18
If I do the self diag test, I get the mysterious PBR error ?
I've had it re-gased and presure tested - OK !!
Anyone know someone in Brisbane that can FIX this for me b4 summer starts
https://www.sau.com.au/forums/topic/48741-gtr-mechanic-in-brisbane/
Out of interest, do you know anyone with a 32 GTR you can pinch the A/C control out of and swap over? Be very cheap and easy to fix then, just grab a new (read: second hand) A/C control and your right. No labour charges, etc.
Just a thought, dont really know anyone in brisbane I'd trust with a gtr :(
Had my aircon fixed just recently at Brisbane Tuning & Turbo at Woolloongabba 3393 1588. I think they use the radiator - aircon guys across the road, but all is now good. Something to do with a pipe that tends to deteriorate in the skylines. Sounds as though your prob may be slightly different, but they should be able to help.
Guest Variable
You could also try Sterling Auto Electrics at Montpelier St Bowen Hills 3216-0907. They just rebuilt my compressor and also repaired the control unit. They were the authorised repairer for the warranty on my car. Speak to Roger. I gave him the AC section of the R32 GTR workshop manual as a reference as well so he shouldn't have any problems.
How much did it cost Robocop to rebuild the air con compressor? I'm up for one of them as well. Being told from different places to just get a new one or recondition the old one. I've got two. My original one borked so I bought a second hand one and the same thing happened within like 2 months.
Can somebody post up or have a thread with all the contact details for our sponsers , as I need someone to hook up my Profec B , and I have found out I have a nice little leak in my zaugst manifold , so that needs to be replaced and the manifold machined to stop it happening again !
P.s does any one have a 33 gadge cluster , mine is fruited !
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
