On the way home from work, got pull over cause my blow off valve was too loud by an under-cover cop & recieve a defect note. The undercover cop told me that my exhaust noisy, air filter & blow off valve was NOT standard. Pictures was taken during the process for evidence. And that I have to attend EPA test (Lidcombe) blah RTA blah blah BLUE SLIP.
Have anyone gone through this trouble and can advice what should I do next? I got rid off all my stock parts. Can anyone let me borrow they stock BOV or air filter?
Thanks.
https://www.sau.com.au/forums/topic/48758-bugger-defect/
remove the blow-off valve and plug the hole for the test, box up your pod filter, make sure your exhuast is not noisy and has a cat(go to an exhuast shop that has a DB meter). The guy at Lidcombe last time I was there ( got sent there with my wrx which had major mods) was a pretty nice bloke actually.
Lidcombe EPA is differen't to the RTA ,Lidcombe EPA doesn't have an emission tester they only test for noise.
https://www.sau.com.au/forums/topic/48758-bugger-defect/#findComment-984486
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
