Just wondering has anyone done any dyno runs with toluene?? Just did two runs on the weekend, one with out and one with Toluene. 160 with out and 166 with the Toluene in. The mixture was only 7:1 and still got a result, just a fluke or has anyone else also had any good results?? :confused:
https://www.sau.com.au/forums/topic/4890-toluene/
Originally posted by U ZCREAM
Hmmm, you should be careful with that stuff. I hear it can dry out your injectors. But if you're only using a small amount for a short period, you should be fine
You are thinking of methanol (I think?). Toluene doesn't have this effect. The problem with toluene is getting a cold start when you run too high a mixture on a cold day.
MattR - It's good stuff isn't it.
:D
I've had a test on mine, no dyno time just a nice 200kms worth of driving. You will find that you can run more boost as well (within the limits of your headgasket and turbo of course). I ran a brief 14psi to test and it went fine.
With extra boost I'm sure you can get more than 166. BTW what mixture did you run?
From memory mine was 25-30%, I'd say a 10-15% would be better without a remapp unless you go extra boost.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-76174
Gav as far as I know Toluene an Metholbenzene are diffarant according to the material safety data sheets. Toluene can be bought as a solvent or as a fuel addative, if you buy it as a solvent you pay about $50 for 20 litres if you buy it for a addative you pay about $70.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-76952
Actually correct chemical name IS methylbenzene, (methobenzene is also commonly used but is a misnomer).
I stole 4 litres when I did my chemistry/metallurgy degree (too many years ago now) and mixed it in the fule tank of my EK Holden (202 tripple f*ck yous, a lumpy seat and exagerators).
Thems were the day me boy!
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77134
MattR.. You run a bleed setup don't you?
You should be getting boost drop to 12 maybe 13psi up top.
Slap more boost in to it.. Maybe up to 17psi in the mid but it will drop back off to 13psi up top anyhow..
I ran my turbo like that for a while didn't damage it as far as I know.. Now with the EBC it holds 15psi all the way to redline and made 164rwkw with a untuned ecu.. So with a tuned ecu i might crack the 170 mark.. :D
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77251
http://forums.skylinesaustralia.com/showth...25&pagenumber=1
This is an previous thread on toluene, covers most of the questions, including the myth about toluene perishing fuel hoses.
BTW I think Boostmeister had a dyno run with 30%toluene mix and got 2rwkw extra without raising the boost any (where the extra power lives)
MattR; The stock turbo shouldn't have the boost raised past 1 bar anyway, so its of little value unless you get it rebuilt with a steel wheel.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77831
Oh you still running stock cooler..
Maybe thats why the octane boost made such a difference as the air is hot and maybe there was really slight detonation where the ecu was pulling out timing and with the octane boost there was no more detonation..?!?
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-78163
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
