Just wondering has anyone done any dyno runs with toluene?? Just did two runs on the weekend, one with out and one with Toluene. 160 with out and 166 with the Toluene in. The mixture was only 7:1 and still got a result, just a fluke or has anyone else also had any good results?? :confused:
https://www.sau.com.au/forums/topic/4890-toluene/
Originally posted by U ZCREAM
Hmmm, you should be careful with that stuff. I hear it can dry out your injectors. But if you're only using a small amount for a short period, you should be fine
You are thinking of methanol (I think?). Toluene doesn't have this effect. The problem with toluene is getting a cold start when you run too high a mixture on a cold day.
MattR - It's good stuff isn't it.
:D
I've had a test on mine, no dyno time just a nice 200kms worth of driving. You will find that you can run more boost as well (within the limits of your headgasket and turbo of course). I ran a brief 14psi to test and it went fine.
With extra boost I'm sure you can get more than 166. BTW what mixture did you run?
From memory mine was 25-30%, I'd say a 10-15% would be better without a remapp unless you go extra boost.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-76174
Gav as far as I know Toluene an Metholbenzene are diffarant according to the material safety data sheets. Toluene can be bought as a solvent or as a fuel addative, if you buy it as a solvent you pay about $50 for 20 litres if you buy it for a addative you pay about $70.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-76952
Actually correct chemical name IS methylbenzene, (methobenzene is also commonly used but is a misnomer).
I stole 4 litres when I did my chemistry/metallurgy degree (too many years ago now) and mixed it in the fule tank of my EK Holden (202 tripple f*ck yous, a lumpy seat and exagerators).
Thems were the day me boy!
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77134
MattR.. You run a bleed setup don't you?
You should be getting boost drop to 12 maybe 13psi up top.
Slap more boost in to it.. Maybe up to 17psi in the mid but it will drop back off to 13psi up top anyhow..
I ran my turbo like that for a while didn't damage it as far as I know.. Now with the EBC it holds 15psi all the way to redline and made 164rwkw with a untuned ecu.. So with a tuned ecu i might crack the 170 mark.. :D
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77251
http://forums.skylinesaustralia.com/showth...25&pagenumber=1
This is an previous thread on toluene, covers most of the questions, including the myth about toluene perishing fuel hoses.
BTW I think Boostmeister had a dyno run with 30%toluene mix and got 2rwkw extra without raising the boost any (where the extra power lives)
MattR; The stock turbo shouldn't have the boost raised past 1 bar anyway, so its of little value unless you get it rebuilt with a steel wheel.
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-77831
Oh you still running stock cooler..
Maybe thats why the octane boost made such a difference as the air is hot and maybe there was really slight detonation where the ecu was pulling out timing and with the octane boost there was no more detonation..?!?
https://www.sau.com.au/forums/topic/4890-toluene/#findComment-78163
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
