You've checked the globe? Did you replace it with a known working one? sometimes you need a magnifying glass to see a break in the filliment. Could be a dadgy connection to the back of the head light. I cant comment whether skylines have a LH and RH fuse for the headlights because I haven't needed to check, but if theother ones working its normally a problem with the globe.
Sumo
  dstylez said:
i'll try to get a multimeter to test it tomorrow. how do you get access to the switch to take it apart?
take the steering covers off and then you will see , i think 2 little bolts that hold it in place and a couple of plugs and you take the stalk out , very easy once you have the covers off .
