ever since putting on my FMIC and EBC whenever i run more than stock boost when i'm excelerating my car makes a flutter sound from the turbo side of the motor, i pulled my stock bov to check it but it seems fine, the cooler pipes are tight but i have not check the turbo outlet pipe cause i'll have to pull the other pipes off to get to it.
what else could it be, the more load the car is under the worse the flutter.
https://www.sau.com.au/forums/topic/49551-help-fludder-sound/
not sure, but lucky its just a flutter :D
when i put my fmic in it seems to have maxed my ecu. i get a flat spot between 4500-5500 now. i'm gonna have to buy a new ecu (powerfc) or get a piggyback to fix it. much more expensive than i thought it would be :*(
lindsey34 - from what you say, it sounds like this happens when you are accelerating rather than while changing gears.. is this correct?
if so, sounds like a surge issue. I'm not too sure on a resolution. first time I have heard this happen on a stock turbo.
Jaff - all you might need to do is change the spark plugs and gap the new plugs to 0.8mm. go buy some $4 each plugs (ngk copper ones) and make sure the gap is 0.8mm. that should fix your flat spot.
still doing it the more boost the worse it is.
i'm sick of driving with stock boost might call ice and see what they think.
do you think it could possibly be the wastgate causing the problem.
you know when you excelerate how the pod makes the shhhhhhhhhhhh sound well when mine is boosted it sounds like shh, shh, shh, shh, shh, shh, shh, shh ? my brothers car has exact same mods but doesn't do it.
no the gasket is fine.
and I still highly doubt it's the bov.
what boost does this start happening at?
like at stock it's fine.. does it do it at 9psi? or 10psi?
play around with your boost controller.
start at stock and then increase by 1psi untill it starts happening..
and when it does happen, what does your boost gauge do? does it keep rising steady or does it move around when you hear sh sh sh sh sh ???
you are using an after market boost gauge right? not working off the stock gtst one i hope..
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
