1 of the most powerful street S15s in Australia)
Year: 2001 model (car in immaculate condition - motor done less than 1000km on dyno - never ever street driven)
Detuned for street. - Custom 600HP garrett roller application by RACE PACE.
Engine : SR20 DET - Tough as nails non-stroked JUN/TOMEI/HKS SR20DET
SPUN a conservative 477.5 rear wheel kilowatts on Race Pace Dyno in April 04 just before MAS04 with T51R SPL setup.
With new turbo setup - should see around 500HP.
(NOTE: ALL PARTS IN CAR -inc motor, turbo, handling, wheels, bodystyling ARE BRAND NEW - NEVER STREET DRIVEN - ONLY FOR SHOWS.
MODS:
- NISMO 1000CC INJECTORS
• JUN 1.6MM METAL HEAD GASKET
• JUN PISTON RINGS
• JUN SR20DET BOTTOM END BOLTS
• JUN SR20DET HEAD BOLTS
• JUN SUPER FORGED CONRODS
• JUN SUPER FORGED PISTONS
• JUN TITANIUM VALVE RETAINERS
- Jun - machined forged SR20 prepped block (sleeved and wedged)
• O RING BLOCK
• PORT / POLISHED HEAD
• TOMEI CAM PULLEYS
- BOSCH external fuel pump with custom surge tank
• SARD FUEL REGULATOR
- Tomei - poncams
- Tomei titanium valve springs
- Tomei solid lifters
• HKS HI’POWER 3inch CAT BACK EXHAUST SYSTEM
• HKS LASH KILLER KIT
- Exceedy twin plate
• ARC ENGINE SUMP
• HKS Type R (108mm) Drag INTERCOOLER
Micro tech LX series
- Bosch individual coil packs
• 18INCH MAGNESIUM F1 TECHNOLOGY RIMS (worth $6000 new,not a scratch on them)
• CUSCO BRAKE CYLINDER BRACE
• CUSCO FRONT STRUT BRACE
• CUSCO REAR STRUT BRACE
• CWEST CARBON FIBRE BONNET
• D-SPEED WIDE BODY FLARED/GILLED FRONT GUARDS
• CWEST FULL BODY KIT
• JIC MAGIC COIL OVERS
• NISMO CLEAR INDICATORS
• NISMO REAR ARM ASSEMBLY
___HAVE RECEIPTS FOR PARTS THAT TOTAL $32,000 PLUS___ not inc labour or purchase of car.
FAST FOURS COVER CAR - plus featured in many Aust tuning mags as one the best built street S15s in Australia.
MELB AUTOSALON / SYDNEY FINAL BATTLE / GLO SHOW DYNO AWARD WINNER.
NO OFFERS - GOING INTERSTATE FOR WORK SO HAVE TO SELL - $48,000
******* dont pm me on this forum - pls contact or sms me on 0412414173****
Hi.
I will SMS you but for everyone's info, is the airbag intact and other such considerations for interstate buyers who may have to get the vehicle inspected for registration? Has it ever been involved in an accident? I assume it is an Australian delivered 200SX, not a Silvia? Is it a Spec R or Spec S? Manual or auto? The mods list is comprehensive but other info is required.
Thanks.
PS. You get a free bump...
Hi.
Thanks.
Hey I didnt get an sms from you, but to answer you questions: yes the drivers side and passenger side airbags are intact. No accident history what so ever, but has had a few slight key marks from jealous on lookers at car shows. Yes it is an australian delivered vehicle - manufactured in april 2001. Its a Spec R, and yes it is a manual (smirk ;P). yes the list of mods are extensive, so extensive, not all new mods were mentioned in detail. Trust me, an offer like is very hard to come by. Give us a call if you want further info on my car, as there have been so many potential buyers flying from all states to Victoria to see it, but no one has yet to come up with the money. As the saying goes : money talks..... bu11sh1t walks. Have a nice day.
BMT
May I ask which rims are on the car - from the above pictures, the gray or the gold?
Whats the interior like? condition? any gauges, stereo installed????
Thanks
Daniel
It'll have the silver magnesiums on it. 18 by 9 and 10 rear. they have 33gtr brembos on the front with project u slotted & crossed drilled rotors, and standard rear with endless pads.
Car will be taken off the market at the end of the month. Possibly will be keeping it as too much money has been spent. As the saying goes........... money talks...... bu11$hit walks
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
