:headspin: 1994 GTST Skyline
HKS T51R SPL turbo
Custom Tubular stainless manifold
HKS Wastegate
Apexi AVCR Boost Controller
Microtech LT12s
Large FMI
Bilstein Suspension
HKS Springs
3.5in mandrel exhaust
17" Alloy Wheels
New Tyres
Custom Plenum
650cc Injectors
600hp Clutch (new) and lightened billet flywheel
Bosch 044 fuel pump and surge tank
Alpine stereo (amps, speakers, subs etc)
Forged oversized Pistons
Forged RB26 I-Beam rods
Tomei 1.8mm metal head gasket
Replaced all gaskets
Machined Crank
New bottom end and conrod bearings
plus more! Reason for sale - just finished putting the engine back together (forgie's etc) and found that it has cost too much money
Price starts at about $50,000, as that has been what I have spent, but realistically according to the market at the moment , asking around the $29,000 mark is quite reasonable
https://www.sau.com.au/forums/topic/49717-r33-gtst-large-hks-t51r/
Interior has been completely colour coded metalic silver and the boost gauge and AVCR controller is on the dash. I f anyone wants pics, i don't have any until after the weekend as the head as to be retensioned for running in procedures, so after the weekend i'll have some pics for whoever wants them.
Update on power as was dyno tuned on the weekend
231rwkw at 15psi on pump fuel and still on base timing. When we increased the timing by 1 degree, the power jumped up by 8kw at the rear. Now modifying the intercooler pipe (inlet side) due to a possible restriction and going up to 20-25psi on Saturday, then tinkering with the timing for ultimate power.
Will be at this years Jamboree, it's white in colour and a HKS sticker on the rear quarter windows, so if any one is interested, please feel free to approach me and ask some questions...... i won't bite!
Reason for sale - just finished putting the engine back together (forgie's etc) and found that it has cost too much money and due to new family additions, something has to go (baby seat in this skyline is not a good idea)
Dude Sell the baby on eBay. This beast soudns way too sweet
Ok, cool
New baby and seat for sale, 7months old, doesn't scream or dirty nappies, user friendly, 6" chrome momo's on stroller with 100shot NOS for up hill dashes to the change room and one owner since new!
At least we all still have a sense of humour amoungst us all!
OK update agian 23psi = 305rwkw, need to send away the microtech to have a 3 bar map sensor upgrade to get more boost, we need 30psi+ to get what I want!!!!!!!! Couldn't go above 23psi due to cheap crap hose clamps boosting off!
And yes it is running down the strip at Jamboree!
before rebuild 13.27 on 7psi, about 180kw! standard cams!
I will have to get the print out and scan it to send you the dyno graph, i will have it at Jamboree if you will be there.
For engine bay pics post your e-mail so I can send them to you.
That seem rather weak considering how amount of air a t51 must be moving at 23psi. There has to be a restriction somewhere else in ur system causing the low power figures.
What compression is it running now with the 1.8mm head gasket??
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
