Hey guys,
I have a new ride that i will be cruising in. Yes its still a nissan, but it aint a skyline. instead its a sr20 powered 180sx, sil80 actually. Its in resonable condition - a bit of mix match colours. So if ya see it around give me a wave aight.
https://www.sau.com.au/forums/topic/50158-new-ride/
Here are its mods -
ASE Big Front mount Cooler
OS GIKEN Super Single Plate Clutch
s14 gear box
HKS super dragger exhaust
AVO bov
king springs
gab rear adj shocks
walbro fuel pump
gab front and rear swaybars
triple core drift radiator
Its makes 170rwkw. Yesterday, i took it out for a little bit of a squirt against the 33 and brothers 32 and i cained them both. Now im a skyline lover but damn this car was an animal compared to the lines. I couldnt believe it so we want a few more times and i still came out on top.
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-998618
compared to my 33 and brothers 32 it handles very differently and frightening at times. I can feel every bump in the road, probarbly due to its suspention set up. When it was purchased i knew it was obviously set up for drifting. Still i cant get enough of driving it and the lines have been garaged since. On a side note though, i noticed that the str20 has much more toque than the rb20 which was quite surprising.
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-999804
the Sr20 has nice toque down low but i rekon it is a very rough engine, a lot of virbration compare to RB. Which is not nice for criuse.
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-1001076
The ol SR20 is good for the street.
Much more mid range but they don't have the top end scream like the RB's.
Not that thats a bad thing. I get sick of the rb20t's top end scream to get anywhere. :P
We will have to see how it pulls up against Darrens and I's stocker R32's. :)
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-1002307
Yeah, the 32s are a bit better out of the box handling wise, but the 33 can be made to handle, just suppose it comes down to whether or not you want a classy ride or not:p
That vibration Darren is probably increased by the mission mount, I just fitted one, and it makes a noticeable difference in cabin.
I would love to come for a ride when she is all up and run in - yours and Joels lil stocker 32s are very phat.
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-1002322
yer well...just gotta sort that bearing problem in the box, then shes all ready :) .....class and all :P
I do have new engine mounts and the mission mount, so id say it does have some part to play in it....
Turbo and manifold due in 1 week :) .....then it sits till i can afford to fit it :P
good luck on the new car Nozila btw :)
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-1002335
Pictures!
I will get some pics soon atm my gf's dad is the only person i know of who has a digital camera and getting it off him will take a while. :P
Do they still have street meets on wensdays at air as i would like to see how it goes too.
With regards to handling, it quite scary as you feel every bump/pot hole/sewer hole - basically any street in adelaie. Could this be due to the fronts having only king springs while the back has gab shocks or as a result of the sway bars and/or both these mods.
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-1002498
I had the car since last week hipster. I have added a few more mods to the line but because it hasnt been tuned ever since i owned it, the car eats alot of petrol - i think its running too rich and thus has remained in the garage. the sil80 was considerably cheap for the level of mods it had. you will see why i said considerably cheap when you see the paint work it has or when i post pics up - basically drift appearance.
https://www.sau.com.au/forums/topic/50158-new-ride/#findComment-1002641
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
