Car is back together and running quite well. (WOOT!) I've put Helix Synth in it to give it a rinse, and will junk it in favour of MOTUL or redline. Also need to change the diffs gearboxes etc.
Anyone know where I can get either Redline or MOTUL in Darwin?
Also discovered that the front left towhook is separated from the chassis rail. I need to get the chassis checked.
Anyone recommend a workshop that will do a good price / good quality for non-insurance work? :rofl: John
https://www.sau.com.au/forums/topic/50584-qn-oil-and-panelbeating/
