Hi Guys,
My RNN14 GTI-R is now up for sale. Here is all the details I can think of!
12/92 Nissan Pulsar GTI-R, black. 79000 k’s.
Interior:
Momo “Race” steering wheel
Razo gear knob and pedals
HKS type one multi timer/meter
Trust/Greddy 60mm boost gauge
Genuine Nissan floor mats
Factory power sunroof (very rare option)
Power windows
Retractable power mirrors
Air conditioning
Engine:
Chipped ecu
Exhaust – 3 inch front pipe, 3 inch high flow cat, 3 inch custom cat back system
Braided turbo oil feed line
Braided clutch line
Trust frount mount intercooler
Trust Type S blow off valve
Turbosmart bleed valve (set to 0.8 bar)
Urethane Engine mounts
M’s pod filter
Veilside oil filler cap
Cusco radiator cap
Twin core alloy Calsonic radiator
NGK high tension plug leads with NGK platinum spark plugs
Suspension and brakes:
Factory ABS brakes
Front strut brace
Rear strut brace
Race brakes front and rear brake pads, with slotted rotors
ADR compliant braided brake lines all around
Rebuilt rear callipers
Clutch pedal bracket
Tein type HA damper and height adjustable coil-over suspension
Whiteline Anti-lift kit
Whiteline adjustable rear sway bar
Whiteline link bushes and sway bar D bushes
Whiteline camber kit
Exterior:
Clear side and front indicators with silver fusion indicator bulbs
Alloy wheels with Toyo Trampio Tyres
New front bumper bar with tow hook cover
Stereo and alarm system:
Sony Head unit with 3, 4 volt pre outs
Clarion two channel amp, powering;
Boston Acoustics 6.5inch splits
Alpine 2 channel amp, powering;
Rockford Fosgate 10 inch sub
Flashpoint Level 4 alarm with 3 point immobiliser
History:
This car was imported in late 2002, by JappSport (formerly Fuji Motorsport) in Sydney. I was the first Australian owner, buying the car in December 2002. Since owning the car I have spent in excess of $10 000 to make the car what it is today, a neat, quick reliable street car :rant:. The stereo and alarm set-up alone was over $3000 and all suspension components were bought brand new with around $3000 spent there too.
Always serviced with Castrol formula R, 10W60 and genuine Nissan oil filters. Brake fluid used is Trust Super DOT 4.
All suspension components were professionally installed and set-up at Whiteline Suspension in Sydney.
All of the stereo and alarm components were installed by Lifestyle Car Audio.
The exhaust was custom made by Liverpool Exhausts
All other mechanical/service work was carried out at Rice Engineering in Sydney
The car has been dyno tuned to 156 all wheel kilowatts at only 0.85 bar boost at Premier Auto Centre.
Timing chain tensioner has been replaced and the timing chain inspected. CV boots have been replaced. Clutch master cylinder has been rebuilt. Starter motor has been replaced. Front wheel bearings have been replaced. All accessory belts have been replaced. Fuel filter has been changed. Engine has excellent compression across all cylinders.
The car has just under 4 months registration remaining.
This car has been owned and cared for by a true nissan enthusiast. The only reason I'm even selling it now is because I now own a GTR skyline. Registering, insuring and maintaining two cars is a bit silly for someone who doesn't even drive to work!
Asking $19 000.
I can't re-size the pics at work and one is 115kb the other is 142, if someone could do if for me so that I can upload them that would be great. Or whoever wants pics can request them here and I'll email them. Car is located in Sydney.
Please contact me (Richard) on 0405 186 433
Cheers. :cheers:
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/
Thanks mate.
Had plenty of calls and interest, but no-one has walked away with the keys yet.
Also, no swaps for other cars, I've already bought another car which is why I'm selling this one!
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1046852
link to pics says its been sold??
That's weird! Maybe they do that when you don't re-sucbscribe the ad? hmmm.
I'll give carpoint a ring.
Anyway, it's still for sale :D
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1062078
  • 4 weeks later...
bumped, still for sale. I'm now getting more keen to sell as the GTR is getting closer to arriving in Sydney. Anyone who's interested don't let the price put you off, it's a great car and I'll be happy to negotiate with an interested buyer.
Richard
https://www.sau.com.au/forums/topic/50616-rnn14-gti-r/#findComment-1087249
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
